big bolt patter conversion
trbodrt
so. cal
I already have disc brakes on the front of my 72 dart but I want to convert to the big bolt pattern, I know i need upper control arms, spindles and calipers and rotors from the 73 dart donor car I have, can I use the proportion valve and brake booster/ master cylinder that is already in my 72 is the question.
okay, i guess it's easy enough to take the prop valve from the donor car, thanks
you don't need the later prop valve if you already have KH 4 piston disc with that prop valve on the car.
The booster and master should work as well.
even better, I'll take as much off the car as I possibly can.
Yep, grab the prop valve off the donor car.
Good call Jim.
Last question is do I also need to replace the lower ball joints?
