Biltrite Torque Converters
DentalDart
Ozark Missouri
I've seen the guy posting on the facebook mopar pages and reached out to him. His price is great and in my price range. He said it would be a stock TC housing rebuilt to the stall I wanted.
Has anyone used one of these? Hes out of Illinois and seems like a good guy but as always I worry.
Thanks!
Thanks!
That's a 180-200 dollar convertor.
How much is he asking
Thanks!
Never heard of them but they seem to have good reviews.
Try a search on Google for them and you will see the same.
Trouble is, imo, how do you know what stall you want? Normally the builders know. Maybe get an idea from PTC or Dyymamic and then have him build you one?
I called PTC, Dynamic, and TCI
TCI recommended 22-2300 for street car and 2800 if I have an external trans cooler which I have.
Dynamic recommended 26-2800 stall that he would build.
Precision didnt really offer advice just said he could do a 25-2800 stall for me.
Biltrite I just asked if he could build a 2800 stall converter for my 727.
I did looked over the TCI "how to choose the right converter" and it points me to the 25-3000k stall range. 2800 seems like a happy medium lol. I think anywhere in the 25-2800 would be a good stall going off past threads with similar setups.
That's the high side for a cut convertor.
They are 200 around here.
Delenzi converters does them for me.
So what's the difference between them and biltrite vs Dynamic, PTC, etc? The latter are in the $6-800 range for a customer converter. Aren't Delenzi and Biltrite doing the same??
Small vs large company? I would assume the ptc/dynamic are fully new converters vs rebuilt stock converters?
I dont know the truth though really.
There was a thread awhile back where a guy got a converter from Precision of New Hampshire for about $250.00. I can’t find it though. Kim
Why dont you guys just match ur convertor to where you cams power band starts ??
I've always been told to have a custom one made. Technology these days are miles ahead of the past, so getting an off th shelf is a waste.
Not entirely true, a very well known convertor builder told me , mine was probly pretty close to what i needed , when I talked to him about building one for me .
Altho , I wouldnt care if it was 3-400 rpm tighter myself--------
But Bob, didn’t u say ur car is underperforming? Kim
Beyond a certain point, efficiency is the issue. A high end convertor is a custom peice from shell to stater to fins etc...it will go when you dip the throttle like stock, it will not drag rough idling engine down at idle in gear.
The lower priced, cut fin converters allow slippage, and can in a maxed out stall version create a ton of heat below the stall/full lock up. Average hot rod 2600-2800 is fine, some do fine with 2400 and work great.
It's like hedman vs tti...
Both are upgrades...but one is better and does not have negative by products like ground clearance, too small for max power.
But I'd take hedmans over stock 318 manifolds. I'd take a cut high stall over a stock stall any day.
Converter shows like... off idle slip, under stall speed is slippy.
Example
.. If it stalls to 2600 rpm ...you will see the off idle flash 'under normal operating pedal' will rev the tach 1400-1600 rpm.
