EL5DEMON340
Make sure the plug is in the oil gallery, that is very low oil psi.
Also the oil pressure is low, 5 pounds at idle after warm, 23 at 2k rpms, 32 at 3k rpms.
are you using arp main studs by any chance ?
So far, I see nothing to blame the carburetor for.
You sure it's not a bad fuel pump?
LOL
how does the engine run for 300 miles with a bad fuel pump
lean?![]()
No the main studs are not arp, but the rod bolts are. The reason the oil level is fine and why I blame the carb, I believe the bowl would drain into the manifold, the plugs were way rich and as I discovered that the oil was full of fuel I rebuilt the carb, so now the oil level is fine.
the reason I asked this is there 3 or 4 members had oil ps problems lately because the arp studs were interfering with the oil pump not letting it seat properly causing pressure leakage .![]()
Hear-say to me there has been issues with pump casting clearances on some pumps. Never seen it though.
except in this case Phil never mentioned any symptoms of a lean condition, then 4 plugs way rich![]()
The grey film isn't moisture, but it could very well be just a new motor breaking in.
