My bad! I didn't know you had one of ours, I was talking to a magnum in general, which you're right, is usually in the hole more than an LA. To my knowledge at this point in time, they are zero'd regardless.Could be just rod/piston/crank throw stacked tolerances, but they were consistently .011 across all 8 in the hole. Mine is old 08-09.
Is yours a BPE short block, or the long block? got me curious now!
-Highlight the portion of the text you don't need, then hit backspace, & it will leave just the part you want.
