California Flash
Looks great Denny! It was a treat to check it out in your shop last month. Top notch work as usual.
Thanks for coming, I love having company, I was probably still talking to you as you rolled out the drive way.
36 degrees....but sunny out today.
good eye....gonna have to "fix" it, so looks like new matt-ghost stickers for the doors. Likely take more time to peel the originals off and remove the door handles / locks than it will to re-install correct door graphics. I see a few "adjustments" while I'm at it.
can't you overlay a gloss clear/gloss red 'the' onto the existing first to see if you'll get away with it? worth trying before removing the lot and starting again.
neil.
Glad you put up pictures of it outside, I couldn't really see all the ghosting while inside. Looks terrific.
back at ya'
April 1975 CarCraft cover.....and the 10 x 10 color photo proof of shot compliments of Peterson Publishing achieves
cold and windy today but off I go for a 3-mile drive to drop the Duster off for the updated door graphics install. They were good....just not good (large) enough.
door graphics 2.0 . Bigger California Flash, centered correctly and lined up with the center door crease instead of the bottom.
finally found a tuff wheel adapter, got it painted and installed. End of mission. Next stop....California
