Badart
Senior Member
I know this has been beat to death, but my combo might be a bit different and I just want to make sure that I am making the right choice for the cam.
73 Dart, 318 (Low mileage reman long block) Low compression I am sure, 904, most likely stock convertor, 3.91 gears, 675 heads (small valves), eddy performer intake, holley 600 cfm 6619 carb, hooker comp headers, 3" dual flowmasters.
This is going to be a street machine. I would like to have a slightly choppy idle but good low to mid rpm performance. Is the Comp XE256H or XE262H cams a good choice for this combo? I know with either of these I will have to change the springs.
changing the heads is not really an option or machine work because I am building a 440/727 combo to go in this later, but in the mean time I do want to enjoy driving it. Thanks.
