1. zsn0w
    zsn0w Well-Known Member
    66
    19
    Sep 5, 2018
    Cincinnati, Ohio
    Local Time:
    4:21 AM
    I'm doing the final parts selection for a 408 build I've been planning for awhile, and I'm wondering about my choice of carb. This is going to be a street engine that I want to do well at low to mid rpm. I'm more concerned with keeping performance there good than I am with maximizing the top-end. I was originally thinking I was going to go with a Holley 750 CFM ultra double pumper, but now I'm wondering if a different carb like an Edelbrock 800 CFM AVS2 or a 750 CFM street demon would be better. Open to any suggestions at all, these are just the ones that have caught my eye so far. This is also going to be going into a B-body, I've just had much more engagement about engine questions over here in the past than on FBBO. Thanks!
  2. yellow rose
    yellow rose Overnight Sensation FABO Gold Member
    28,537
    24967
    Jun 19, 2015
    Central Washington
    Local Time:
    1:21 AM
    Go on Facebook and look up dominicthumper and get him to do a carb for you.
    Or mark Whitener.
    Or BLP. Or Braswell. Or Dale Cubic. Or Dambest (I forget his name).
    If you buy a carb from one of theses guys you most likely won't even change a jet. If you buy an off the shelf carb, you WILL have to tune it. It's a pay now, pay later deal.
    • Like Like x 1
    • Agree Agree x 1
    • flyfish
      flyfish C8H18+N2O = :-D
      2,339
      925
      Apr 16, 2007
      Indy
      Local Time:
      4:21 AM
      Well, my car is 75% race and 25% street...so my opinion is slanted that way, but with that said I would stick with the Holley 750dp. It will still drive well on the street AND make more power than the others if needed.
      • Agree Agree x 3
      • flyfish
        2,339
        925
        Apr 16, 2007
        Indy
        Local Time:
        4:21 AM
        Braswell is SERIOUSLY overpriced....Just my opinion as someone who likes to keep a few dollars for other things.....
      • yellow rose
        28,537
        24967
        Jun 19, 2015
        Central Washington
        Local Time:
        1:21 AM
        Ever use one? I have. And BLP. And a Cubic carb. Worth every penny. Every time. Just like an off the shelf cam, and off the shelf carb is the same.
        The real issue is most guys bolt the carb on and leave it and the bitch about how the idle sucks, no fuel mileage, fouled plugs and all the rest.
        You can either pay up front, do the tuning yourself and spend the time to do it, or buy off the shelf shit and live with it.
      • 67autocross
        67autocross A new iron curtain drawn across the 49th parallel
        1,380
        832
        Jul 23, 2010
        Winnipeg
        Local Time:
        3:21 AM
        I have had great performance with AED carbs, give them a call.
        • Agree Agree x 3
        • RustyRatRod
          RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
          73,160
          48641
          Jun 7, 2010
          Georgia
          Local Time:
          4:21 AM
          So you want a carburetor recommendation but ALL you GIVE is a cubic inch displacement. LMAO
          • Agree Agree x 2
          • mbaird
            mbaird mbaird
            7,049
            3833
            Dec 10, 2005
            boise, Id
            Local Time:
            2:21 AM
            I had Pro System build on for me.
            Stipulating mostly street with some strip time. It came out around 900+ com IIRC ..actual cam will vary depending who and how they flow them. Havent dives the car yet but it fired right up and idled well.
          • ocdart
            ocdart Inland Mopars Car Club FABO Gold Member
            9,727
            3069
            Nov 5, 2006
            North OC, SoCal
            Local Time:
            1:21 AM
            I believer you can get in touch with Dominic on FABO, goes by Thumperdart
            • Agree Agree x 1
            • mderoy340
              mderoy340 Well-Known Member
              2,433
              1216
              Aug 2, 2012
              Melbourne FL
              Local Time:
              4:21 AM
              Get a holley based carb with replaceable bleeds and restrictions, also buy an AFR gauge set up and have at it. You will learn a lot and know how to tune when you are done. All the new carbs have the fancy metering blocks with way to much emulsion in them and run pig rich on a street car OOTB.
              Carb Tunning
              The other option is pay someone for their knowledge.
              • Like Like x 1
              • Thanks! Thanks! x 1
              • zsn0w
                66
                19
                Sep 5, 2018
                Cincinnati, Ohio
                Local Time:
                4:21 AM
                I CAN give you any other info you want if you ASK me for what you need rather than making fun. I obviously do not know what all info you want to know to be able to make a recommendation. It’s going to be a 408 with edelbrock performer rpm heads and a Hughes 2832 hydraulic flat tappet cam. That’s .565 and .571 lift with the 1.6 rockers I’m going to be using. Hughes Engines Around 10:1 CR. Ld340 intake. Headers.
              • RustyRatRod
                73,160
                48641
                Jun 7, 2010
                Georgia
                Local Time:
                4:21 AM
                Nobody's makin fun. You can have a stock stroke 340 that needs a 1050 dominator if it has all the right stuff, much less a 408. Are the heads as is or will they be ported? Head flow numbers would be great. Car weight, converter type and gear and rear tire size all play a role.
                In order to give a good recommendation, we need it ALL. Why should we have to ASK when this is something YOU need? If you want a good and accurate answer, you need to give good and accurate information. Come on guy, you know how this works. Nobody's tryin to be funny here. 'Cept you leaving out important information.
              • yellow rose
                28,537
                24967
                Jun 19, 2015
                Central Washington
                Local Time:
                1:21 AM
                You are right. I just don't know how much Dom comes on here lately. I see him on FB all the time. If the OP is serious I can PM him Doms phone number.
              • yellow rose
                28,537
                24967
                Jun 19, 2015
                Central Washington
                Local Time:
                1:21 AM
                If you are going to use a dual plane intake you need a bigger carb. A single plane can use a smaller carb.
                That's why I said spend the money up front and get a carb for exactly what you are doing.
              • 12many
                12many Well-Known Member
                1,861
                2281
                Dec 14, 2016
                South Carolina, Thank God
                Local Time:
                3:21 AM
                With the street demon I can attest to excellent idle, throtlle response, crispness, acceleration, wot etc on the street in general (and strip after exploring the limits of tuning) You will have to tune it period, even just for the street. But it is cheap, just buy the tuning kit and work methodically on tuning it and you likely will be set. Or go with one of the off the shelf mid priced Holley (or variants) but expect to tune it for you setup. Or go all out like others have advised, and likely not have to mess with it much at all. (I have no experience with those so have nothing to say pro/con) Others here far more knowledgeable. I have run the entry priced 750 street demon and now have a mid priced AED 750 on my stroker setup and have had to tune for my setup on my own. You will need to tune either route, maybe a little, maybe quite a bit on the first two options.
              • yellow rose
                28,537
                24967
                Jun 19, 2015
                Central Washington
                Local Time:
                1:21 AM
                So where are you with your tuning? Have you done any more since you changed to the quicker opening power valve?
                Everyone should read that thread.
              • Dartsun
                Dartsun Mopar Dude
                2,109
                1873
                Feb 12, 2012
                Springfield Oregon
                Local Time:
                1:21 AM
                I’ve got a 750cfm street demon I pulled off my 408 blueprint engine if your interested in a slightly used carb. Dustin
              • 12many
                1,861
                2281
                Dec 14, 2016
                Local Time:
                3:21 AM
                Its on hold at the moment, hopefully will be back at it within a week or so. I was having a tip in, off idle hesitation afterwards (before the boosters kicked in) with the leaner primary jet change along with installing the 10.5 PV. Had to go through what I may have altered that might cause that issue. Determined that I somehow changed the secondary butterfly opening for idle, so have reset that based on research. Just haven't had it out for testing. It's been in the mid 90's for over a week, so I've just been soaking in the pool (and beer) It's about all I've been doing!
                • Like Like x 3
                • pittsburghracer
                  pittsburghracer Well-Known Member
                  5,197
                  9585
                  Apr 20, 2016
                  Freeport, PA.
                  Local Time:
                  4:21 AM
                  I ran 9.80’s with a newer style 750 Holley on my 408. I loved that carb so much that I boxed it up and stuck it on my shelf when I switched to alcohol. Just in case. Lol
                  • Like Like x 2
                  • rumblefish360
                    rumblefish360 So close, yet so far away FABO Gold Member
                    41,100
                    12572
                    Jun 21, 2005
                    New York, on a Island
                    Local Time:
                    4:21 AM
                    As far as cfm is concerned with the CID and cam known, 750 cfm is right about what you need dead nutz on.
                    Now what carb you want is another story. I truly believe that IF you yourself are going to tune the carb, then you should decide on what manufacturer it is going to be. Be comfortable in what your using. Don’t listen to a soul. Use what YOU want and feel good about tuning. Because for a street vehicle, any HP or torque difference between the various carb manufacturers and styles is slight and only visible on the dyno or track at the top end. Where your rarely driving.
                    • Like Like x 1
                    • mbaird
                      mbaird mbaird
                      7,049
                      3833
                      Dec 10, 2005
                      boise, Id
                      Local Time:
                      2:21 AM
                      Holy Shit !!! New phone...Fucking Spell Check!
                    • rumblefish360
                      41,100
                      12572
                      Jun 21, 2005
                      Local Time:
                      4:21 AM
                      We all knew what ya meant... LOL!
                      • Like Like x 1
                      • mbaird
                        mbaird mbaird
                        7,049
                        3833
                        Dec 10, 2005
                        boise, Id
                        Local Time:
                        2:21 AM
                        Thx...
                        I spent the last several days tuning the 750 VS on my 5.9 to get rid of a burble at low rpm cruise ... Once you get the car running there will be a learning curve for the total tune for most any carb you buy.
                        I am hoping the 800$ + Pro system carb doesn’t take as much tweaking as the off the shelf Quick Fuel 750 VS has taken so far ! It is coming along though... GET A WIDEBAND!
                        it will save your sanity!
                      • James Clews
                        James Clews Well-Known Member
                        157
                        186
                        Aug 25, 2018
                        Australia
                        Local Time:
                        6:21 PM
                        I run a 800 AVS carb on my 410 stroker and it is awsome. 22mpg with 3.91 gears on a run. Still runs 11.4 qtrs. I think a new AVS with the new boosters would be even better, but personally I would go multi port EFI before that but that is only me!
                        • Like Like x 1
                        • BrianT
                          BrianT Let's go!
                          5,521
                          1267
                          Mar 13, 2007
                          Kansas City, Mo
                          Local Time:
                          3:21 AM
                          I'm running a Edelbrock Thunder 800 on my 408. All I had to do was set the idle and idle mixture. I paid $100 for a tuning kit with jets and rods. When we ran it on the chassis dyno the AFR was right where it needed to be so I sent the kit back! I have no complaints with the carb at all.
                          Edelbrock Thunder Series AVS Carburetors 1812
                          • Like Like x 4
