snailpower
first off I know this is like asking "whats the best oil," everyone has a preference.
Heres my car specs:
Mostly street driven 72 scamp, full weight, AC.
Currently running Eddy 1406
Rebuilt 99 360 magnum
HEI ignition, stock mopar distributor (parts store type HEI)
LA air gap intake
EQ heads with light bowl work and light shave
9.6:1ish compression
stock mag pistons/crank/rods
Hughes cam 224/226/110
1.6 adjustable roller rockers
Dougs headers, 2.5" exhaust
3:55 SG 8 3/4
2200 stall, 904
I will be mostly street driving this, but occasional strip use and suspension is set up for handling so there will be some turns carved up.
I have the 1406 650cfm on there, it runs ok but its the carb from the 318 that came out and wondering if I am better off with something different. Mostly I want to get rid of the electric choke since it never gets too cold here. The couple times I have gotten into the secondaries since break in I have gotten a bog so it definitely needs some tuning as is, I have an Innovate wide band O2 I will be hooking up shortly to aid in tuning once the motor is broken in.
I have been eyeing the new AVS2 which seems awesome, but wondering if I go for the 650cfm, or the 800cfm? Im open to any suggestions, want to see what everyone thinks.
Heres my car specs:
LA air gap intake
3:55 SG 8 3/4
2200 stall, 904
