LOL, here comes nuthin'...
Alright, so I did say earlier that this 9800 series carb is a test-bed, right?
What this means is that I have several base plates that I use, the key difference between these being the primary throttle plates have an air bypass holes drilled. I typically switch these over when:
1) I feel that my adjustable air-bleed setup might allow me to revert back to factory non-drilled plates, most often I'm screwing around with the jet and meter rod sizing here
2) I play around with the WOT angle on the secondary bore, i.e. factory 81 vs MP recommended 86-88 setup for single plane intakes (although so far I have been using the factory 81 deg setup, short of THAT ONE TIME when I ran the 86 one)
Yeah, so
"THAT ONE TIME" I swapped the bottom plates.
I use the Lokar cable setup for both the throttle and transmission kick-downs, which means that I really should re-check the cable operation each and every time. To be honest nothing should have changed with just the plate switch...alas, that wasn't quite the case!!!
Turns out I somehow lost about 1/4" linear cable travel. In terms of this translating to a degree (rotation) of the throttle, well, it was enough to leave the secondary butterflies opening maybe 2/3 of the way at most.
Now I know I said earlier that this was checked to make sure the secondary plates were fully opening, and I know we did this...but somehow I missed something. My wife was helping me (not a fault of hers) but the two throttle return springs I use make for a heavy gas pedal feel and I recall her saying she "couldn't push any further" LOL, and me telling her "just floor it honey"...ha ha...oh boy! Anyways, I could have sworn we even retested with the springs removed, but I can't argue the reality here, the linkage was off.
Take a look at the attached pics:
1) MOPAR_TQ_WOT_throttle-problem - shows the problem in that the secondaries are NOT fully opening
2) MOPAR_TQ_WOT_throttle-manual - shows the FULL opening when manually forced
3) MOPAR_TQ_WOT_throttle-linkage_fix2 - shows the corrected FINAL setup
I properly adjusted the cable and reverted all the other setups back to where they started, took the car out for a test drive and was immediately rewarded with:
1) almost 0" vacuum reading at WOT
2) massive "butt meter" reading (LOL - yeah, pulled way harder this time)
3) much nicer WOT AFR reading, albeit far too lean for my liking - 13.5-14.3
AND
3) SURPRISE => I swear, "when it rain it pours", eh?
So, during the last such pass (weather related really: I am out in the county, crappy roads - a good crown to the road surface, weather has cooled off and even after driving for some time the tires just won't hook) I buzzed the motor ever so slightly HIGH, I suspect near 7-7.5K. This happened in 1st gear as I tried to do a steady pull starting at about 2K and mashing the pedal. Well, car initially lurched forward a few feet and immediately went sideways on me, but b/c I'm on a county road (ditch on both sides) and I am just trying to stay on the road at this point in time, I am not watching my shift-light on the tach, audibly though I hear the motor scream past that normal "time to shift now" level and so I shift to 2nd and get rewarded with a LOUD tick!!!
Grrr...I immediately left off the throttle, toss my ratchet shifter into N, RPMs drop down to idle and stay there fine...but yeah, there is an audible tick but it's that "for sure it doesn't sound good" tick.
So I pop the hood open, driver side is not happy, no obvious damage though, just a tick from under the valve cover. Oil pressure reading fine, no change from previous readings...so seeing as I'm out in the middle of nowhere I limp this thing home.
I take things apart, #3 exhaust pushrod is loose. Hmm, collapsed lifter maybe? I yank the rocker arms and
THERE IT IS (or not actually): the lash cap is MIA!!!
I go looking for the darn thing, not in the head though, so I fish out my snake camera, looking through driver side lifter bank, nothing there either. So it's either popped straight over to the PASS side, or made it's way past all the other moving pieces into the oil pan (I am saying a little prayer right about now).
Quickest way to find out is to drain the oil and stick a magnet into the pan hopefully finding it. I am not feeling terribly good at the moment I tell ya...worst ideas are going through my head, I mean that cap while small is pretty hard, so had it gotten stuck anywhere it would have caused some damage.
Alright, I setup to do the oil change. My oil pan is a Milodon 8 qt piece which has a magnetic drain plug, and as I pull the plug out I get a slow trickle of oil instead of the gusher I am normally rewarded with!!!
Holy crap, I think the lash cap got captured by the drain plug magnet and is now somehow blocking the oil drain hole. Yup...indeed...there she is, poke a small screwdriver through and more oil comes. Took a while to completely drain out but sure enough, the cap was there. I grabbed my other magnet wand, poked around some more, finally managed to pull that plug through the opening, but boy the "Speed Gods" must have been smiling on me (and laughing I would hope) because the oil pan opening is literally like 0.005" wider than the diameter of that lash cap...so yeah, BARELY and I mean BARELY, I was able to extract the cap out!!!
For now gents, I am in the process of re-assembling it all. Weather permitting I just want to be able to fire it up one last time before the car is put away for winter and make sure there is no other damage.
All in all, the fact that the lash cap escaped indicates I had experienced some valve float. I run the recommended Comp Cams beehive springs (26056) and it's only been a couple of seasons, but they could have gone weaker and the roller lifters themselves may have played a role. I originally set them up with 1/2 turn past zero pre-load, so this time around I am going with the full 1 turn the Comp Cams 2012 instructions recommend.
Thank You everyone for your feedback and insights in troubleshooting this issue. Turns out the problem was quite simple to correct and had I not missed a check when swapping parts I would have never gotten to this place.
