I've got some aftermarket solid upper control arms that are a bit longer and helped with caster and bump steer. I'll try to think off what co. I bought them from. They were great to deal with.![]()
All ears as the lack of caster on my avatar is what is causing me issues. Not going back to the track until I can get some positive caster (I have 0 to -1* caster now and car is very unstable at speed). Waiting to install my new SPC fully adjustable UCA's to address the issue.
@LO23M8B - I like your analogy!!![]()
Yep, if ya had a 60s Friso style Chopper, positive is Raked OutTop is back .
Bicycle has + Caster
From what I've read, the More +, the More Stable!I always liked more caster than the skosh chart shows on mine when I was drag racing.
The further the suspension extends, the LESS caster you can get.As the skosh chart mentions, try to figure out the ride height when the car is accelerating down the track, then jack the front end up to that height when making the alignment adjustments.
I believe that they were Magnum Force. They also power coated them for me.I've got some aftermarket solid upper control arms that are a bit longer and helped with caster and bump steer. I'll try to think off what co. I bought them from. They were great to deal with.
That's exactly what Peter Bergman explained to me when I bought the SPC arms from him. My car does sit a bit higher and lifts quite a bit on launch (pics suggest about 4" of lift) and down the track. But c'mon, there's cars that are a LOT faster than mine that hold the front end up and don't have this stability issue. So I am counting on the UCA's to give me some caster and address the stability concern.The further the suspension extends, the LESS caster you can get.
In other terms, these cars can get the MOST caster the lower the front end is. If the front is cranked way up, positive caster may be impossible to get.
It is just how they are designed.
Do you work at a shop with an alignment rack?That's exactly what Peter Bergman explained to me when I bought the SPC arms from him. My car does sit a bit higher and lifts quite a bit on launch (pics suggest about 4" of lift) and down the track. But c'mon, there's cars that are a LOT faster than mine that hold the front end up and don't have this stability issue. So I am counting on the UCA's to give me some caster and address the stability concern.
One thing a higher ride height setting does do is cause more toe change when the wheels drop down. I've used the methods described in the Mopar Performance Chassis manual to measure this. The tie rod end "looks" longer and adds toe-in when the wheels drop. So it's all a balance that I clearly have wrong and will get after when I install these arms and set up the alignment.
Thanks. Looking for someone to square up my mini-van in or near the D.^^^^ No, just a shadetree mechanic at best in my own garage!!
I'm hoping I can get those kind of numbers!!Just finished up driver side, 5* + caster, 0* toe up and down, 0* camber up and down. Tie rod arm was a little long trying to center the length on both sides, Will do Pass side tonight. Once that side is right I’ll add the 1/8” toe in
