Change your auto console to 4 spd with pics
The cut out is not actually required, at least not to clear standard Hurst competition plus shifters, see my posts above. Standard auto bases clear just fine. Unless you are doing a concourse restoration I wouldn't cut the base. As for the measurement I can't help you.
I have a question that I have not found an on here. My question is in converting an auto console base to a 4spd base what is the measurement from the very front edge og the console to the front of the cut out for the shifter hump or bump ?I included a picture!
Sammie if you still need this post here and Ill measure/get pics.
I could use some pictures of where the brackets mount to the hump. With measurements if possible. If anybody has them.
Hey 4spdragtop,
If you have a good auto console it is very easy to convert to 4-speed but, only if you are using a hurst shifter. Using the inland shifter is where problems raise their ugly head. All you need is the 4-speed top plates with a hurst shifter and they will bolt right up. I have done the conversion myself and it looks factory correct. Be careful not to lose or damage the speed nuts that hold the top plates in place! They are a ***** to find new or used!!
Have a 67 FB F-S, 273, 4 speed. The console have that ugly hole to the right of it. I have read that the purpose of it was to easy access to the shifter mechanism. Want to cover it, but can't find any p# of it. Any one knows it, or where I can get? Brewers don't have it.
As far as I know no one re-pops the shifter cover. I think they were a fiber board like the glove box material so fining a sound one will be difficult.
