here's a few eBay choices:
http://www.ebay.com/itm/130699384897?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
PRO-SERIES BILLET CLUTCH 1500-HP HEMI 4-SPEED 1-3/16 x 18; 130T FLY, 6 BOLT CRNK
1500-HP Rated Drag Race Clutch - Single Disc
Dual / Triple Disc Available Up to 3000-HP
Pro Series I - Aluminum Flywheel Integrated w/ Clutch Assembly
McLeod Racing and Boninfante Friction have joined forces to create the ultimate 10” street clutch for the ultra-high horsepower cars from 800 to 1,500 horsepower. This is a fully CNC-machined 6061 T-6 aluminum construction utilizing the latest in high performance drag racing technology.
Easily handles cars with 800-1,500 horsepower in a single disc configuration.
Fully red anodized 6061 T-6 Billet Aluminum construction
Fully adjustable spring pressure, adjustable stands and counter-weighted levers
Choice of sintered iron or metallic discs
Complete, includes ARP hardware, pre-set height gauge and weight kit
Street or Strip Capability.
Application: DODGE,PLYMOUTH 1961-1978 V8 318,330,340,360,383,400,440 ; 130T R/G 0BAL 6-BOLT CRANK 1-3/16 x 18 INPUT
McLEOD RXT TWIN DISC CLUTCH MoPar 23-SPLINE HEMI 4-SPEED - SMALL FLYWHEEL
http://www.ebay.com/itm/120722121437?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
RXT Twin Disc
Rated to handle 1000 horsepower with pedal effort similar to stock.
The RXT Street Twin clutch kit is an ideal clutch for the extreme horsepower street enthusiast with an economically priced clutch kit. Able to hold up to 1000hp, the extreme version of the RST clutch kit is for those who have kicked it up another notch and are still streetable. Ceramic facings on the clutch discs provide slightly aggressive engagement with a soft pedal effort will make this clutch suitable for most street performance enthusiast. Kit includes: Pressure Plate, two ceramic friction discs, floater plate, adapter ring & pilot tool.
Application: MOPAR V8 ; Use w/ Small Diameter 130 Tooth Flywheel. 1 x 23 Input
McLEOD RXT TWIN DISC CLUTCH 18-SPL HEMI 4-SPD 143T FLY
http://www.forabodiesonly.com/mopar/showthread.php?t=297932
RXT Twin Disc
Application: MOPAR; Use with 143T Flywheel. 1-3/16 x 18 Input
