converter size
ian
hi guys ,heads, are indy 360-1 245 cc cnc flow343 @ 650 intake 225 ex @650 ,indy intake,750 bg t d 1.6 rollors. , 410 cube ,11.8 comp ,259/265 @ 050 109 l/c 3 degee advance .200 figures are 176 in 171 ex solid flat tappet, 610 615 lift 1 3/4 pipes 4 into 1, trans brake 904 , low first 26/10/15 slicks 3500 lbs. what converter size and stall ,diff ratio for this car to et its best. thanks ian
what stall do you think bob.
is this a race car, street car, street strip? 8 inch sounds good for an all out racer defanitly not street
thanks for replys, its a steet strip car driven week ends only.
I would consult with whoever you are buying the convertor from. I like the people at Dynamic real well. Also, a good convertor won't be cheap.
The right way to find out is to call a converter company & tell them all your specs they will tell u what you need. People can tell you what worked for them . But might not work for you. You want best performance call the converter company..
