Coolant on concrete...
inkjunkie
Just got done doing the annual maintenance on our two daily drivers. I ended up with one of them having the coolant start dripping overnight....it ended up missing the drain bucket so I have a bit of a mess. Mopped it up with some rags but the floor still feels damp...any suggestions?
soap and water will wash it away
-- Stop the dripping first.
Speedy dry. Like $10 for a huge bag. Oil Dri I think is the name. Should be able to get it at the parts store.
Kittly litter works too.
Grocery store kitty litter. Dirt cheap, works like the expensive oil dry fancy name stuff.
I use special kitty kitty litter in the red bag from wal mart. Pour it on the mess and take your foot and scrub it in, then sweep it up.
The trick is to lay it on then grind it in with your foot. While it's still wet if you are able to get to it then.
