cranking compression
SRT_DSTRHOLC
"There is never enough horsepower...."
California
What should cranking compression be with
Rhs heads chambers at 64
cam is xs282 244@50 67 ABDC @.015
kb 107 .40 over square decked
3.58 stroke
I'll guess in the 165ish range if static is 10.7:1
Should run on pump gas without much issue and good quench.
Actual will depends on gasket bore/thickness, piston in/out of hole, etc.
head gasket is .038, piston is 0 decked...I believe when I did a compression test it was at 180-190 but closer to 180. Im running 91 also
Ran a compression test on similiar motor..yesterday
10.8 with eddy 63 cc heads....038 head gasket..
I was getting right at 165 psi...
but i think our elevation in vegas kills some of the compression...
Run on Pump gas?
Yes I do, but ok..Just wondering because I thought I read somewhere that it should be 190-200
