duey_roc
Figured it out
Figured it out
Guess my diagnostic skills arent as bad as some people on here think
So it turns out it was the intake manifold being cracked underneath. I went and got a new intake and put it on. Fired right up. All 8 cylinders running good and the carburetor can adjust like it should!
LOL. Pics or it didn't happen. Just messing around.I say without proof it didn't happen
HOLY CRAP, now it's even more confusing.
From the plugs picture it looks like cyl 1&4 would be the ones missing, and the other cylinders running too rich.
There seems no rhyme or reason to the lean and rich mix of the plugs.
If it was a booster leak, then why is number 1 lean?
If an intake leak, then why 1&4 ?
Maybe it is the intake cracked.
You checked for tennis balls in the runners right? :-D
Let's see the crack. Glad you got it going duey
We have a winner.
So ive had this 360 torn apart 3 times now and im going to scream since ill most likely be doing it again. Heres whats going on...
I have a brand new set of J heads on the motor. I had them put new hardened valve seats in, valve grind, and surfacing all sides of the heads. For some reason, nothing happens when i pull #2 and #8 plug wires out. They're giving spark but im not getting any action into the cylinder. Ive tried multiple sets of spark plugs and they all do the same thing.
The bottom end is stock. Original rings and bearings. I haven't gotten around to doing a compression test on it, but im thinking i have bad piston rings. If i have spark, and i know my cylinder heads are good, i can rule those out. The only other thing i can think of is low compression caused by bad piston rings. What does everyone think? angry9:
That`d be a highly precision drywall T square:coffee2:I question the straight edge, what did you use?
That looks like an old piece of steel, not a granite table or machinest straight edge.
But glad you fixed the problem.
Well I'll be damned....
Wonder if the welding caused the warpage?
Also a possibility. As long as proper torquing sequence is followed and the engine never reaches critical temperatures, the new manifold should be just fine.What if the crack was caused by the manifold warping? Will the new manifold warp also?
Since you are dead set on changing the intake because it is your problem, I will be interested in buying it from you, for the right price. post a picture of it and I just may purchase it from you.
Let me know when you sell that intake.
