Determine 2 or 4 Barrel - by just looking at it?
matthon
Just from these pics alone, 65 383, is it a 2 or 4 barrel?
I would remove the filter to to be sure. Some two barrals had air cleaner mounting the same size as four barrles. Or a side view of the carb should tell you. It will be wider front to back. I would guess this is two barrell.
With the limited info provided.
My guess....
383 2 Barrel . Single snorkle air cleaner and the position of the visible carb linkage.
Here's a 1965 4 barrel setup I found.
Are we sure it's a 383 and not a 361?
65 Polara, base bb was a 383.
2 bbl.
You can tell by the throttle return spring bracket.
I thought there might be a giveaway item.
I thought the air cleaner was the same, 2 or 4, in the c-body, in 65 anyway.
My understanding is 65 went from flat top 10.1 for both 2 and 4 barrel, to dished 9.2 for 2 barrel.
Discovered the 65 c-body left engine mount is the same as the 67-68 bb a-body.
I'm going to say four barrel because the fuel line enters at the passenger side rear. I believe a two barrel would be front center?
The pictured 383, or possibly 361, is two barrel carburetor equipped. Although it is hard to tell fully conclusively from the angles of the pictures, which conveniently hide some other clues, an original four barrel on an original intake manifold in 1965 would be a Carter AFB. The left front mounting for the AFB and the intake mounting area would be visible, unless the angle and the debris in that area is hiding it.
The point about the fuel line toward the rear for an AFB, is good, if it was comparing to a Carter BBD 1-1/2 two barrel which has the fuel line entering the front. However, the 1965 383 and 361 original two barrel carburetors were Stromberg WWC models, which has the fuel line entering on the right side, albeit a little more toward the front compared to an AFB.
The 1965 C-body air cleaner for non-California two barrel and four barrel 383 engines was the same. Also the same for the 1965 non-California 413 four barrel, including Imperial, as well as the 361 two barrel in B-bodies.
The pictured 383, or possibly 361, is two barrel carburetor equipped. Although it is hard to tell conclusively form the angles of the pictures, which conveniently hide some other clues, an original four barrel on an original intake manifold in 1965 would be a Carter AFB. The left front mounting for the AFB and the intake mounting area would be visible, unless the angle and the debris in that area is hiding it.
The point about the fuel line toward the rear for an AFB, is good, if it was comparing to a Carter BBD 1-1/4 two barrel which has the fuel line entering the front. However, the 1965 383 and 361 original two barrel carburetors were Stromberg WWC models, which has the fuel line entering on the right side,albeit a little more toward the front compared to an AFB.
Made me think of this @Vaanth :thumbsup:
Searching the interweb I found pics of 2 barrels with the fuel line in front and on the side.
4 barrel appears to go back farther on the side.
Also, it appears 65 was a 1 year only c-body in a number of ways, subframe, engine mounts, air cleaner, etc.
Just typing that out above.
Was thinking this.
383 was the base bb in the 65 Polara c-body.
I think it's a 2 barrel, didn't really care when I took the pics, then got curious when it wasn't obvious.
Is the engine in your possession now???
You going BB!
I got a 66 383 from a 66 Fury II and 727 from same. I changed all the front accessory drive parts to be 67 up versions (its going in a 67 Dart GTS clone) easier to get the right parts when it is all from the same year.
You going BB!
No, scheduled to pick up car on Sunday.
Already have a bb a-body.
Want it for the 65 c-body rearend, direct bolt in to our 58 Coronet, didn't know it had a 383 so that might go into it as well.
