I saw that Motive was Italian made, so that's a good thing.
is it really? *side eye*
And the only way around the limited selection would be to swap the entire pig(which I'm not against), correct?
I shoulda snagged an empty 83/4 pig at moparfest a couple years back for $50![]()
and a small 204/214 melling replacement cam... Launching with care would pin you in your seat to well past highway speeds and launching carelessly would just produce tire spin.
I have Randy Ring & Pinion 489 center section in my car for about 20 years. And last 15 years stroker engine and now 6 spd manual trans. I change gear oil regularly to help it last.About 20 years ago, I bought a complete 489 housing center section with 3.55 gears and Sure Grip from Randy's Ring and Pinion. It was all new parts including the housing. It has performed flawlessly. They are still in business at this website: www.randysworldwide.com
I mean if your Garfield... or really like Lasagna it's a great thing. Then again, the Italian Mobsters were pretty rowdy.. so the gears must be good right?
Whew! Now I feel better.It's a joke bubba. I run motive gears and love em
Hp is about 63% of torque at 3300 rpm vs 42% @ 2200 rpm, guess were talking a LA 360 so probably around 350 tq (147hp) at 2200 rpm and 400 tq (252 hp) @ 3300 rpm basically around an 100 hp difference give or take.If you figure it needs more stall speed, absolutely do that first!!!
You might find it wakes up the car so much you don't need a gear swap.
Think about a power /torque curve. How much more power and torque does a typical ic engine have at 3300 rpm than 2200? (Without changing a thing in or out of the engine).
that is... uhhh... sizeable for a street cam. even more so if you're down on cubes.The cam is an old school Comp 20-247-4
I bought here(probably too big but couldn't pass up)
https://www.compcams.com/magnum-236...r-273-360.html?SID=j2orr5rmdfmu64agmq3i93dc1d
I'm thinking like OMM said it needs more stall obviously, but do that first?
Thanks all.
What size motor and c.r.Thanks for all chiming in guys, and I apologize for lack of info on my part. I'll include more.
I emailed Cass/Dr Diff, for the 741 the gears are Korean made. Everything else with "kit" is USA.
I emailed Motive and theirs is Korea as well?? Website says Italy tho??
The trans I have is original 67/904.
Thanks all.
it's on a 106 with 110 so at least you've got that going for ya.
i'd stall it up first, personally. hope you have compression...
Yeah all this talk about 2400 this and that. Yeah if maybe you want a pussy for a car. I'd put a tight 3200-3500 in it all day long.that is... uhhh... sizeable for a street cam. even more so if you're down on cubes.
Yes do the converter first . You will see, It will make the car perform a lot better then a gear change. on the street.Thanks for all chiming in guys, and I apologize for lack of info on my part. I'll include more.
Thanks all.
Were the 67's the course splines like the 65-66's.Yes do the converter first . You will see, It will make the car perform a lot better then a gear change. on the street.
Look for a deal on a newer trans with a better converter . May find a whole unit cheaper then a new converter.
The converters in the 67's were the worse for performance.
yeah they were the early ones that are almost impossible to find performance converters for.Were the 67's the course splines like the 65-66's.
Ask @66fyssh about the converter I recommended for his car and how much he likes it. He wasn't skeered. He got just the one I recommended and loves it.
Steve Motive performance gears in the Orange Box are made in Italy , they also have Blue Box street gears for some makes (9inch Ford etc. ) also made in Italy ,,, they do have gears made somewhere in Asia and are cheap price wise ,, the part number for these gear sets has an A at the end . i do not think they make the cheap gear for 8-3/4 differential. even Timken bearings has gone offshore i am seeing more made in China on their boxes and other boxes say the bearing is made with imported components. if you need a complete differential let me know , you may have seen my diffs at Moparfest.Thanks for all chiming in guys, and I apologize for lack of info on my part. I'll include more.
Thanks all.
