AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 26,614
- Reaction score
- 13,851
Cam was "degreed in right", and was offered in post #1
Yes, I read that he said that, but did he know how to do it right or did he just set it up at 110 degrees? I was just asking him to double check this AJ. That's all. I've seen some pretty funky things when guys were "following the instructions carefully"!Cam was "degreed in right", and was offered in post #1
All in by 2500 is for race cars that have big TCs, and two modes of operation; namely idle and WOT.And they don't run vacuum advance.
A streeter has to satisfy a bazzilion different operating parameters, not the least of which is a whole lotta time spent at under 3500 rpm. What is the point of sacrificing driveability below 3500 in the name of "I gotta race Distributor", or some such story. If you don't have a 3500Plus TC than you can't have all in before 3500, plain and simple. Well you can but it totally messes up part throttle, and economy.
See at part throttle and steady state, and lower rpms (sub 3500 say), the engine could be wanting 30 or 40 or occasionally 50 degrees of timing. But as soon as the throttle begins to tip in some of that has to drop out. And the faster you tip it in, or the heavier the loading, the quicker it has to drop out. So if your centrifugal timing is already walking a thin line to detonation, the trickier it will be to to satisfy the cruise and PT requirements.
Since you rarely ask for full power below 3500, and a 340/360 usually has more than enough cubes to spin-up street-tires even several degrees short of optimum timing,it seems to me somewhat foolish to completely throw away the tune in this most used area.
So as a compromise,recurve your dizzy to provide 34* at 3400, and idle timing of 12 to 14. Then install the biggest Vcan you can get (I have found none bigger than 22*). And start tuning that bad boy. The max timing can be controlled by shimming the arm. The rate of advance can be controlled by the little screw inside the hose-nipple.Then when you think you got it all dialed in pretty good; add 2* more initial, to get 36* at 3400, and start over.....And when you get that working, recurve it again to get 36* at 3200 or 3000 if you are feeling lucky....
As the engine starts to get the right PT timing it will be possible to start leaning out the low-speed circuits.
This is the road to fuel economy, cool running, and a torquey bottom end;free from detonation.
But while all this is going on, the engine running temperature has to be stable. If the temp is dancing around it will be impossible to work something out. Impossible. So if your carb is still sucking hot underhood air, don't even bother beginning a tune. You are just cooking the fuel, and cooking the air. And the inlet air temp will be all over the place. And the air-density will be dancing worse.
I've been wanting to buy a distributor machine. Do you recall what they were asking for it? Just out of curiosity.Should have bought this at mopars in the park.
That cam has 4 degrees advance "build in" so I quess I set it to 106. I dont have cam card right here to check what it was.Yes, I read that he said that, but did he know how to do it right or did he just set it up at 110 degrees? I was just asking him to double check this AJ. That's all. I've seen some pretty funky things when guys were "following the instructions carefully"!
Good article you wrote. How ever I dont agree that I should put mechanical timin all in that far 3400 rpm. Earlier I had this engine with smaller cam (268) and old heads (596 ported) then I removed the stiffer spring from stock distributor to get all mechanical advance in at about 2000 rpm. Car got alot more torque at low rpm (in WOT) Is the magnum type heads so different that it needs all in at 3400? I could use small decree vacuum canister that doesnt give too much advance in steady part thorttle.All in by 2500 is for race cars that have big TCs, and two modes of operation; namely idle and WOT.And they don't run vacuum advance.
Have you used it? does It work?
I just did compression test on hot engine and I got 170 psi.You also said somewhere in this thread that the chain had a fair amount of slack. You might have lost those 4 degrees and the cam timing is in a retarded position.
I have a 4200 Stall for sale for a 9043.23 rear end ratio
904 lockup trans and 2200 stall speed custom converter. I havent found bigger stall speed converter here where I live.
14 inch wheels not so tall tires 205/50
Well, Ima gonna pull a Rusty on you; I don't really care if you agree with me or not.Good article you wrote. How ever I dont agree that I should put mechanical timin all in that far 3400 rpm. Earlier I had this engine with smaller cam (268) and old heads (596 ported) then I removed the stiffer spring from stock distributor to get all mechanical advance in at about 2000 rpm. Car got alot more torque at low rpm (in WOT) Is the magnum type heads so different that it needs all in at 3400? I could use small decree vacuum canister that doesnt give too much advance in steady part thorttle.
You are gonna spend dozens of hours fighting your rebellion, and in the end you will either slow down the centrifugal,or disconnect the can, or severely limit it's function. And I'm ok with that for two reasons;1) I'm not paying you to learn on my car, and 2)that's how I learned too.
I am just trying to save you two or three summers of learning.
Now my question to you is did you read all of the article?
Looks like your ego is so big that no one can disagree with you.Well, Ima gonna pull a Rusty on you; I don't really care if you agree with me or not.
