do i need to drill new mounting holes for a V8 radiator in a /6 car?
jasonmrenda
went to install the radiator from the 76 dart into the 67 car last night and it fits perfectly - except all the mounting holes are off. obv the smaller radiator of the /6 has a different hole setup. so at the risk of asking an idiotic question, i assume i need to drill 6 holes to mount the V8 radiator.
does it make sense to attach the shroud to the radiator to make sure of fan clearance and then mark/drill the holes?
sorry for dumb questions ..
Yeah , use the shroud as a guide. Good plan. Only 4 holes reqd though.
its because your using the 76 rad. if you were going 67 slant with a/c to 67 v-8 rad it would most likely bolt right in.
but yes, just line everything up and drill. should be a straight forward job.
ahh thanks all
just wanted to make sure before drilling holes ................
