So Gladys' bottom tank on her radiator started spewin the other day. It was a cheap plastic tank/crimped on aluminum core. Surprisingly, Summit had an all aluminum radiator in stock for her. Thing is huge. 26 3/8 wide core and 19 1/4 high. That's the CORE measurement. LOL Overall it's over 30" wide. That's a heap of real estate. So I got that replaced and of course, then the water pump starts howling. LOL So I got a new Milodon high flow pump and that's what I'm doing today. All I can say is, thank goodness for the Summit card. LMAO. Anyway, I don't know if any of yall are familiar with the Cleveland style engines....the 351C, 351M and 400 are all Clevelands (335 series). The timing cover is basically a flat steel plate sammiched between the block and water pump. The gasket between the timing cover and block doesn't get replaced when you put a pump on it.....but it gets DISTURBED. See where I'm goin? LOL So I said FFFF it and whipped the balancer off and took the timing cover off too to put a new gasket behind it because I JUST KNEW it would leak if I didn't. Lo and behold the 351M in old Gladys has a double roller chain. How bout that? lol Here's where I am so far. Of course Oreilly didn't have the gasket set in stock. I'll have that tomorrow and go on back together. I think I took out about 31 bolts to get "all this" off. LOL Always somethin, ain't it?
