My bracket is different than the above post but does the same job. A bit overkill.Adjustable. Got it at Mancini Racing.Is there an adapter I can get off the shelf that can correct it?
You should be able to use the O.E. bracket that attaches to the intake manifold bolts (Like the first photo.)will I need a new throttle cable or can i modify this one
I believe the kickdown and throttle cables should be both on the upper pin. One inside and the other on the outside. Your kickdown is operating in reverse.I don't like the way that the kickdown cable for the transmission is so high and angled down. Maybe that bracket is not right, it looks to be aftermarket.
I don't know who put the Quadrajet on there, but I would remove that for another carburetor. If not... you may be spending a lot of time on something that might never be right
I think it’s worth crawling under the car and making sure the kick down cable is correctly set up down at the trans.kickdown cable is still in the wrong location..
if the cable is routed correctly it will pull the leaver on the trans back towards the rear of the car.. where you have the cable on the carb it will try to push the cable towards the front of the car...
Nobody on page one has mentioned the carb is twisted on the manifold like a carb mounts to an Edelbrock Torker intake.Have a 74 duster, 360 and 727 with a column shift, quadajet carb, what is correct linkage to be set up? I have no idea where to start and don’t flame me too bad here. Keep in mind we got this to learn on, any input is appreciated
But this is obviously a dual plane intake. Carb sitting ****-eyed maybe confused the modificator, if he wasn't experienced enough.
What intakes other than a Torker have skewed mounts? It looks iron with all the casting #s.
Eldebrock includes a very thin one from stamped metal so hight is not changed. As the normal ones are half an inch or better think and may mess up hood clearances on some applications.Isn’t there some sort of spacer/adapter required when putting an Ede carb on the spread bore intake?
Since it had a q-jet on it, I’m assuming it’s a spread bore manifold.
Or is there a spacer in place that I’m just not seeing?
Yeah you’re right, I’m gonna save for the whole kit and be done with the headache, just sucks because I’m running out of timei don't know what the hell that bracket is you have holding the throttle and kickdown cables.. so this is a knockoff cable? in my opinion at this point i'd just use an entire lokar set up and be done.. will be much less of a headache in the end. the knockoffs have a reputation of breaking..
Dont the Torqueflight transmissions blow up real fast if that kickdown isnt set right?
I’m not sure. Someone will say otherwise. I’m not risking any damage, and who knows the car might have other issues with the transmission, I got the car really cheap knowing that some of it was cobbled together. Just gonna have to start chasing all of them down one piece at a timeDont the Torqueflight transmissions blow up real fast if that kickdown isnt set right?
