66dartgt
This isnt an A body but it is a mope. 82 dippy. We decided to put DOT 5 in my son's car on which we rebuilt the whole system.
We replaced calipers, hoses, wheel cylinders, and master cylinder. We blew the lines out and then installed the bench bled master and allowed it to gravity bleed for an hour or so before hooking the hardlines to the hoses. The master cylinder did not go dry. We then bled the system using the time honored manually bled procedure RR, LR, RF, LF. We thought we had it bled out as there were no big bubbles coming out, only very tiny pin point sized bubbles.
Go to drive the car, well the pedal is real low, we drive it around the block and the brake warning light comes on. Ugh.
That was last week. This week we put it on jack stands and go thru the whole procedure again. Maybe a little better now, the brake warning light is staying off. But now we are getting frequent moderate sized bubbles from each wheel.
So, I do an internet search and find some people recommending heating the fluid as it traps air. So, we do this, we do see a fair amount of small bubbles form and then break, heated to 212 F. After that - well - more or less the same result, moderate sized bubbles that wont go away, even after pumping quarts of fluid thru this thing.
What gives ? Ive used silicone fluid before and had issues with tiny bubbles but geez this is driving us crazy.
I can't think of anything we missed. We've tightened and rechecked all the threaded connections - nothing seems to have helped much.
I am thinking this might be cold weather making the problem worse ? It was below 30-40F in the garage today.
any thoughts are appreciated.
