Drag race steering column?
Cope
Fusing with fire
San Jose, Ca.
What are you using on your race car?
I'm looking for as light weight as I can get yet not get stabbed in the chest....
Chris alston, has a whole kit with a quick disconnect set up for a 5 bolt steering wheel, I put one in my 72, has a stainless steel outer shell and chrome moly rods and two universal joints with weld in ends, just cut to size, I'll take a pic of the engine compartment side, thought I had one in here must have erased it.
AAR, you got a pick of the stock column with the disconnect on? How much distance dose it add to the column (length) , my seat is solid mount so I'm not sure how much closer I'd want to get to the wheel.
Thanks.
That looks clean Bob. How do you like where your dash bar is located? Dose it's location make it hard to get in and out of the car?
Would you mind posting a pic of where your A pillar bar meets the roof hoop?
Thanks.
So that one fits the stock shaft even tho it lists as GM? Kinda makes me nervous that it don't list spline count...
Looks good tho, I think I'll order me up one of those..
Thanks.
Thanks.
Yes..it fits stock shafts....It does not know that the is not a GM....
Thank goodness, if it did know it would expect three times the price...
Thanks, that anwsers my window net question also..
Your car dose not look easy to get in and out but it dose look safe.
