dustoff440
anyone running a set of these...how is the sound and performance
ready for mufflers a buddy recommended these.....
just like everyone else, i love the super turbos. I have the 2 1/2 inch models and find they have just the right mix of idle sound, quiet drone free cruising, and wide open sound. Here is a pic of my home built system.
on a small block yea little too mellow much much better on a big blockI must be the only one against the super turbos ! They were to mellow for me, now running ultra flow welded, much better !!
love the dynomax on my cars. Actually, very tame until you get on them and i don't experience any droning noises that i did with the flowmasters.
been listening to sound clips, comments from here and my buds etc....I'm thinking of the dynomax VT's now looks like they are around 80 each
the reviews said that the "flapper valve" would jingle and noisy at idle, the dynomax tech I called said that they would do that unless you had an x or h pipe installed
nice rumble at idle, not offensive or loud till you get on it...........then WOW
The 2 1/2" super turbos are 2 1/4" internally. And the offset in center out design flows like crap due to the center pipe right in the way when the exhaust tries to make the 180 degree turn. And after that 180 degree turn the 2 1/4" pipe is just cut straight not tapered out to facilitate flow. When I took them off my car and swapped on some Ultra Flo's it was like a cork was taken out of the exhaust. The offset in offset out super turbos are a much better design because the exhaust does not have to squeeze around that middle outlet pipe.
Since then I have replaced that system with a TTi X-pipe 2 1/2" mandrell bent with Dyno Max Ultra Flo mufflers.
