prodart340
I'm almost ready to have some porting done on my eddy heads, and I'm leaning towards shady dell to do the work. Any opinions on this shop or others that you may be familiar with?
The shop has a great rep and Ryan should speak with you before the work is done so you. This way your both on the same page for the work to be done.
Brian @ MMI or was that MII does porting as well. You can do a search on his screen name, OU812.
Shipping costs are not a reason to use someone for porting IMO.
We usually step up the intake valve size in order to get as much from the port as possible.
For a stock replacement head, the eddy is a darn good power maker once ported.
