moparduster
I want to know which yall prefer. Pros and Cons. how much power each can handle. Im building a engine for the dart and i am stumped on which heads to get.
Yes Moper true,I,ve spent quite abit more having them ported,new springs,retainers etc...I,m well in over 2k on the heads alone.Zoom Zoom,you gotta pay to play!Bear in mind OOTB RPMs need a little work. The RHS can be had ready to bolt on. So the catalog price difference is only part of the cost comparison. In the same shape (ready to bolt on), RPMs will take about $2K give or take your shop's labor and springs.
I have the adjustable mechanical rockers (shaft mounted) off a 273. Can I use these stock valve train components on both of the heads mentioned?
you can use the shaft and rockers off the 273...and maybe the pushrods if they are the right length.
but valves no...eddy and rhs have smaller stem size..plus the 273 valves are too small to fit either head...
Ok here is my set up so far. 360, forged bottem end. not stroked, 10.5:1 pistons, mopar purple shaft .533 lift 320 duration, running a 727 with 3500-3800 stall, 4.56 gears, just trying to figure out if i can run RHS heads with out loosing to much power. what do yall think?
that hydraulic cam has about 270 degree duration at .050..
if you got it free....use it.
Talk to OU812 about his RHS heads, they flat out WORK!
How fast do you want to go?
I won't let the cat out of the bag, but, I was impressed.
Whatever do you mean????? Did Brian take it to the track??
Come on now teaser!!! haaaaaaa
