Brewzer67
Posted at FBBO also...
While getting my daily car reading in I found this:
New: Tame Your Carb’s Idle & Drivability With K&N’s ECI Plate! - Hot Rod Network
It's basically a mini EFI setup to fine tune your carb's mixture. For carb guys that can't get it quite right this lets you tune everything a little lean and it enriches it to proper ratios. It doesn't look too complex and shouldn't need a bunch of changes to your fuel system. I think it may have a place for the daily driver crowd but not sure it will have enough capacity to fix mixtures for bigger cfm/rpm guys.
It will be interesting to see how this plays out.
