Installing MSD 6AL and they want me to tie the red msd wire to the two ballast resistor wires which are brown and blue? Only issue I have is that the ballast resistor on my 72 car has 4 connections. There are actually two brown wires twinned together to one post and a green with red tracer on the other post. On the other end of the resistor there is a dark blue wire which has a small black jumper wire with it and goes to the other terminal on that end? So which do I tie together with the red MSD wire? On another note. I also have the yellow wire going to the one plug which is angled on the starter relay. Which wire do I actually plug on to the other terminal on the starter relay?
