Moparman67
I just completed a total rebuild on my '71 340 block that I installed in my 67 Dodge Dart. It was a mild build, .030 over, balanced crank, edlebrock aluminum heads and roller rocker assembly, edelbrock aluminum intake with a edelbrock 600 cfm carb, tti headers. Here are the specifications for the installed Comp cam at the link below. I have the intial timing set at 16 degrees advanced which unfortunately fives me a 45 degrees advanced a WOT. I have tried jetting the carb, adjustung the timing however once the car is warmed up it experiences dieseling(run-on) when I shut it down. Luckily it is 4-speed set-up so I just pop the clutch to stop the run-on. On the highway the engine runs about 200 degrees but can easily climb to 220 when at a stop light.
Anybody have any suggestions how I can solve this deiseling issue. I am in the process of finding a fan shroud because I dont have one installed in hopes to bring the temps down thinking that maybe the extreme heat is igniting the residual fuel. I also only run high-test 91 octane fuel.
http://www.compcams.com/Company/CC/cam-specs/print-specs.aspx?csid=627&sb=0
