Engine Swap
bestbuy19
Active Member
Glendale, AZ
I am getting ready to swap my slant 6 for a 360 Magnum and found out the company that make the spooled motor mounts is no longer in business. Where do I get the motor mounts now. I have a 1975 "K" member.
Try this email to contact Schumaker Creative Services
[email protected]
I think that is the company he is referring too. There has been some postings about Schumaker's business sustainability even before Covid.
I'd put up a wanted add for a V8 K and mounts or see if someone has a set of spool /6 to 360 swap mount.
Schumacher is out of business. I believe Trans-Dapt bought them out.
Would these work?
Engine Conversion and Replacement Kit
I thought there was a post about Mancini having some deal coming up.
Except they are out of stock and Schumaker was the only fabricator. Right now you'd have a better chance at getting a LS swap kit.....
Don't know what this means but heres what appears on Schumachers web site.
We appreciate your patience as we transition to our new location.
Our phone lines are currently down, but you can still reach us via email:
[email protected]
[email protected]
Just found this post , dated sept 2020
Lower it into the bay and find out where spool mounts need to be welded in. Model em out of cardboard and tape and have a hitch shop fab up your mock up or a welding buddy. I'd attempt that before spending $170 on 2 motor mounts that may not even fit. I paid 150 for 351C mounts to be welded onto a 57 Fords Y block mount. What I ended up with was 2 metal boxes stick welded to the cross member. Hell, I could have done that!
^^Those are not what he is looking for.^^ He wants "swap" mounts which are special aftermarket mounts that fit the slant six K frame, and adapts to a V8 engine. The K frame has different mounting ears between slant six engins and small block V8
[email protected]
I've sent multiple emails to that address with no response. I know they are dealing with his wife's illness, but he runs a business. He should put something out there.
