The stock and stock replacement heads don't leave a lot of room. It's likely you won't get the pattern centered without also using an offset fulcrum rocker like Crower makes. Jim (IQ52) may have some additional recommendations though.Have you moved the studs on the EQ Magnum heads; is there enough material in those little cast bosses to move the studs and retain reliability?
Your input on this thread is greatly appreciated, and also thanks for making the correction kits you offer for LA heads and big block heads. I'll be contacting you for a couple of those hopefully in the near future.
