dibbons
This is not the first time my good intentions did not work in my favor. That fluffy battery acid corrosion was taking over the engine compartment of my '96 Dodge Dakota 3.9 liter (OBD-II) pick-up truck that has been in the family since new and currently is my daily driver. Just had the oil changed yesterday.
Spent the last 24 hours breaking down the battery hold downs, battery tray, battery terminals, and battery (a black one). Brought out my Costco size bag of baking soda, mixed up batches of warm water and b/soda and soaked the **** out of everything. Made sure to take everything apart (remove nuts from battery bolts, remove bolts from terminals, etc.) Next day put everything back together. Turn the key, heard a click for about a micro-second, then no dome light, no horn, no nothing.
Brought over another battery I recently had re-charged (a red one) and some jumper cables. Same thing, one quick click and then everything goes dead again.
Remove the black battery and install the red (jumper) battery. (Now without jumper cables) The second battery now installed starts the engine but it wants to die when I let off the accelerator.
Took the battery terminals off. I did not have a batt terminal cleaner brush, so I scraped some lead off the terminals and posts with an awl and a screwdriver until I could see a lot of fresh, shiny areas showing through.
Turn the key again with the red battery, wham, starts up and seems normal. I drive twenty minutes out of town for dinner. After dinner, wham, starts right up and I drove home another twenty minutes and park in the driveway.
Five minutes later return to pull the vehicle inside the yard, hear that micro-click again and everything goes dead. Jump start it with a the original battery (the black one) that failed the first time things went dead. The engine starts but it acts again like it wants to die at idle (like earlier). I drive it five meters ahead into the back yard and call it a day (night).
Not looking for any advice at this time, just sharing what happens when you try to clean up something and it backfires on you. (foto is not my battery- a similar looking internet file foto).
