exhaust flow numbers on my Indy's
BARRACUDA340S
MT PLEASANT IOWA
QUOTE from Ryan J
Speaking of those INDY exhaust ports...................................................
The flow #'s on Barracuda's 360-2's Went CRAZY yesterday.
I sat in disbelief staring at the flowbench........The #'s were stout right out of the box, and then I hand blended the exhaust seats and did a much needed valve job and BOOM......... check THIS out:
LIFT---OUTOFBOX---REWORKED
.200"-----103.5----------107.0
.300"-----158.7----------165.6
.400"-----199.4----------207.0
.450"-----212.8----------220.1
.500"-----223.9----------231.1
.550"-----231.2----------237.0
.600"-----236.3----------244.3
.650"-----240.8----------250.1
.700"-----244.3----------257.0
Those #'s are with NO flow tube......
#'s are better than some CNC W9's I've had on the bench..... Those #'s are just crazy for 59 degree head with non raised port.
Also just FYI INDY has changed the CNC Chamber program, from the one I showed in the pics earlier. Slightly revised the area around the valve seats, to help unshroud. Chamber is 67.5 CC out of Box. I'm still working on intake #'s..... If anything, their chamber revisions helped Ex flow and hurt Intake flow some. I picked up and average of 7-9 cfm with a Valve Job on Intake side. Gonna work on chamber a little and a back cut. These heads are gonna run HARD, REAL hard....
These are my eddy head number's
lift reading cfm
.100 .580 64.22
.200 1.100 121.74
.300 1.60 177.12
.400 2.020 223.45
.500 2.300 254.45
.550 2.340 258.82
exhaust
lift reading cfm
.100 .180 22.97
.200 .660 84.44
.300 1.020 130.78
.400 1.300 166.85
.500 1.520 195.20
.550 1.600 205.57
.600 1.660 213.29
.650 1.700 218.47
Makes my J heads look like antiques........Wait! they ARE antiques!
Nice Job! Those flow more on the Exhaust than my J's probably flow on the INTAKES!
Holy Crap Brett!!
With flow numbers like that out of the exhaust. The intake numbers must be in the top fuel range.
How far is it between gas stations where you live???
:mrgreen: :mrgreen: :mrgreen:
Jack
