externally balanced torque converter with internally balanced engine
Matthew Sermini
Massachusetts
alright so I have a 70 340 that is internally balanced. I'm working on an engine swap and I find out my new torque converter won't work because it is for a 904 non-lockup and I need a lockup torque converter which I can't find at all. let alone with the correct stall speed 10 inch pattern I need.
my question is, is there anyway I can use an externally balanced torque converter with an internally balanced engine. the old torque converter that came with the transmission that actually fits is externally balanced. is it as simple as getting the weights off of the torque converter?
by the way, part of the issue is the new torque converter is a 27 spline and the old one for the lockup I assume is a 26 spline.
Yes, you can just remove the mass. But you have to make sure your using the correct spline and crankshaft register diameter. 65'
Lock up isnt same spline count as late non lock up. Pre 68 iirr is the diff between 18 and 27
Lock up are 26 spline
