Fan switch for a 69 barracuda
Philip Kaufman
New Member
Liberty NY
Anyone have a good fan switch for my 69 barracuda?
You might take it apart and fix it. Aint much to those switches. Main thing is to be sure the switch is the actual fault. The resistor pack mounted in the plenum is a player and common fault.
Great advise!!! I will check that out. O thank you very much!
What year red fish you have?
67 notch. It aint been uncovered and started since mid October though. Happy moparing
My 69 Dart had that switch. I rebuilt it, cutting Teflon to replace the melted sliding part. That switch, plus the 5-pushbutton pneuo-electric switch tend to fail from the high blower current. I installed a relay for the "Hi" position to keep that current out of the switches. A common problem on many cars, and I did similar on my 1980's M-B cars. If you don't install a relay, try to avoid the Hi position.
Thank you very much!
Good info Bill, thanks for sharing!
