DemonDave
Swollen Member
I have two cooling fans sitting in my garage that I'm considering to use on the 360 that's going in soon. Both are clutch fans with serviceable clutches but one is a 19" diameter 7 blade unit, the other is an 18" diameter 5 blade unit. I don't have a shroud to the diameter difference won't be an issue (until I get a shroud!) so which one so I go with?
Thanks!
Thanks!
