GMachineDartGT
Senior Member
Over the next couple months I will be converting to 4 speed. I will have a 904 trans that is fresh with low first gear, deep pan, shift kit and 6K governer weight installed. The converter will be a fresh OE high stall rebuilt. $600.00
I also have a complete kickdown setup with the 3 piece carb rod all the way down to the the trans rod/bracketry. $125.00
I will also have a real nice black automatic console with a rechromed top plate, auto shifter with repro wood ball that works perfectly. The console door will not be supplied. I do have a used decent shape ashtray lid that will be included though. $150
Driveshaft from the Dart 904, 8 3/4. $125.00
Please PM if interested.
Thanks FABO!
Thanks FABO!
