Figured id share my garbage..
We’re just going to call the punk440 dart BACKHALF from now on. That’s all I’m saying.
And………………
Massive vacuum leak on a throttle shaft. First pass it fell flat on its face. 8.4 at 110.
Second pass I babied it out of the hole, slowly rolled into it and short shifted it. 7.1 at 112.
Didn’t break it so I can’t complain too much.
The difference between your car making a clean pass (my brother) and your car falling on its face and going a 3.2 60’
I’ll just say I’m happy I wasn’t recording in the car :mad:
After some much needed sleep and some time for reflection. I had a killer time with my friends and family. Crazy to run 131 to the 1000’ on the street and not be bothered only to be a nervous wreck in the lanes. Cant wait for the next track day, next time I’m going with zero expectations. Check the A/F on the return road photo. Big yikes.
Just know that combustion makes the most heat at stoic (14.7:1 for regular gasoline). Ask any small aircraft pilot, combustion temps get cooler the further you get from stoic -- in either direction. The reason for going rich under heavy load is to both cool combustion, and to better facilitate spark ignition under extreme pressure. You can cool combustion just fine at 16.82:1 AFR so long is it doesn't induce ignition misfires. Be scared at 14.5:1, be very scared!
I was nervous also and have no idea why. All the dumb crap we do and making a pass at Pomona was nerve racking. I don’t get it. After the first one though the nerves went away and it was game on.
Don’t fret the afr on light load, that’s in the carb tune up and right where it needs to be. You’ll get good mileage and like @mpgmike said above it’ll run fine there as long as it’s not misfiring.
Cutting up some old brackets to move the alternator to the drivers side. Gotta figure out how to get the plug in the alternator now, but it opens up a TON of room to build something and let the motor breathe cold air instead of being fed through the radiator. @TT5.9mag has been on me for awhile to do this. Finally decided to mess around and see what I could come up with. Couple spacers and clean up the scrap metal and I’ll be in business.
That looks good, boy that's seriously a full engine bay lol.
I love it. Now we need to get a 5” aluminum 90 on the turbo inlet. I have one we can fit.
Had to shave down a bunch of nonsense on the back of the alternator, ditch the plug and use spade connectors, but otherwise it’s in. Eventually I may need to build a “Z” bracket to bolt to the block and alternator to stabilize it more. Few nuts, washers, and a belt otherwise it cost nothing but time.
Good, that's what I was thinking too.
I had a 60amp denso alternator mounted in almost the same spot, and had trouble keeping them alive. Voltage would drop after about 15 minutes at operating temp. New alternator every year(oreily lifetime came in handy). I hope you have better luck!
So far it’s been on the car for awhile (3ish years if I had to guess) and hasn’t given me an issue but doesn’t have a whole ton of miles on it. Amperage wise it’s lacking at night with everything on but otherwise does good if it’s above idle. Time will tell but thankfully it’s a fairly common alternator if I do need one
okay, just looked at where you had it mounted previously. Probably no difference in heat so I was probably just asking too much if mine. Looks great!
