SD65WAGON
Justin
A bit of bad luck befell my 1965 Valiant Wagon this week, Looks like the original transmission case/ valve body are bad....so the shop has a 71 904 case to replace it with, but as the 65 is a cable operated column shift., I now need to convert this to a linkage floor shifter (Or find a 66 or newer turquoise Column shifted Steering Column) Anyone out there have a Floor shifter console, linkage, shifter set up for sale? Or suggestions ?? Thanks in advance..
