front end rebuild instructions - LCA bushing replacement
str12-340
Vashon, WA
Is there a set of instruction somewhere for reassembling a front end with all new parts. I've done this before a few times but it has been a few years and it would be great to find a set of step by step instructions for the best result.
Regarding LCAs is there a recommended method to get the outer bushing casing out of the arm without scoring the inner UCA surface? I bought a set of tools for Mopar front end work and everything came apart with ease, except for the outer bushing shell in the LCA...
Thanks for any help!
I like this method.
If you don't have a press, you can use a gear puller.
