Fun Fast 318
Now has the XE250H cam and lifter kit arrived with 901-16 springs and double roller timing gear set. Will take out the engine this weekend mainly to replace all the freeze plugs because one of the freeze plugs leaking. Then going to install all of the above things with new gaskets and then paint the engine. Going to buy kb pistons, rods and better heads but for now I'm only having money for this upgrade. That's why I chose the XE250H because on the other cams I needed either higher stall converter or higher gears. Hoping that this setup will bring some fun anyway :)
Hello pompis, I have a full rotating assambly for sale that´s balanced and only needs new rings and bearings if you interested.
forged crank
eagle h rods
kb 167
Wow, you guys are putting money to your 318. :)
I made a "junk yard 318" for my Dart.
Offenhauser 360 manifold
750cfm carb
ported stock heads
cheap (chinese?) exhaust
purple shaft, which had specs pretty close to stock 340 engine i think
Orange ecu
Its not fastest car in this town, but its not slow either.
Some 0-100km/h (0-60mph) testing
[ame="http://www.youtube.com/watch?v=PGITaOmZn0Y"]Dodge Dart 318 0-60 testing - YouTube[/ame]
