If your not doing any kickdown to a tranny there are several to choose from...Lokar makes a decent throttle cable but do not, I repeat do not use their kickdown cable....you can also go to mancini racing and look at their several different throttle cable setups they have and pick one that will work with you intake manifold..will be going from a /6 to 392 hemi, 66 Dart. Not much room for anything! The current gas linkage rotates instead of push-pull. Is there a stock cable/pedal assembly I can look for or should I try to find an aftermarket setup?
When you say oil pressure relief valve, do you mean the relief spring? I've heard heavier springs are no longer available so I was thinking I'd do old skool and just stretch the spring, but by how much I dunno. If you have a source that'd be cool to know.
what are stovepipes?
