Gauge light bulb spec?
Noizemaker
Active Member
Bellevue WA
Hey all,
Quick question... Speedo light doesn't work. Worked once, doesn't come on anymore. All the other gauge and shifter lights work. I got the original owners manual with the car (64 Valiant) and I just spent some time reading it. It specs all the instrument cluster lights as type 57.
That's not a familiar bulb type to me. What's the modern replacement type for it, or am I just blind and not recognizing 'em on the shelf? My local parts store lists NO parts for my car so I'm on my own.
I'm sure I need to just clean some contacts, but in the interest of having everything I need in place, i'd rather have a bulb handy. :)
Actually... while i'm on it, what's the procedure for replacing the bulb? Unscrew the IP surround and drop it forward, or do I have to reach behind and cut my hands up?
Try This Guide. Click on-- Replacement Guide http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/default.htm
Replacing these miniture bulbs can be a pain , then sometimes it's easy. The bulbs are in plastic holders, and being old the holders can break. The plastic tits break off, so be careful.
A lot easier with the dash out, but that's a job.
If I remember right, You turn them about a qtr turn Counter clockwise and then pull out. Most of the time, hard to get a hold of.
Once you get the holder out, the miniture bulb just pulls out of the holder.
http://www.forabodiesonly.com/mopar/showthread.php?t=124556
If you look about half way down this thread there is a picture of the back of a Dash. It shows two bulb holders, they are black, which is what you are looking for.
Hope this helps !
Thanks guys.
From the pic there, the bulb looks like the exact same thing that's in my Neon dash! Appreciate the info.
I am pretty sure my owners manual states the bulbs are a 194 in my 68 Barracuda Owners Manual. I went with a 168 because they are a little briter than the 194's.
Horse of a different color, my friend. The older cars used miniature bayonet base, lamps like the 194 are the "push in" kind
Awesome! I looked for 57s tonight at the parts store... O'Reillys doesn't stock them, apparently.
Oh well. As an aside, learned a valuable lesson tonight. When you're used to plastic dashboards you forget that metal dashboards and always-on ignition switches do not mix. I let quite a bit of smoke out of the wires. Whoops. Now to find out how to put it back in there...
Interesting,
I have my instrument cluster out, pulled a bulb and it is a GE158. (67 Cuda)
So I go searching to find out the brightness of this bulbs (Lumens) and it is 25 lumens and 3watts. Checked on the 194 and it is same 25 lumens but 4watts.
I notice they are T3.25 Wedge spec so I search for T3.25 Wedge and there are a bunch of those. http://www.elightbulbs.com/catalog_search_results.cfm?keywords=T3.25+Wedge
All the way to 10 watts! Although some are 7volts, 12v-14v.
I am going to give this one a try:
http://www.elightbulbs.com/Eiko-49031-1450X-Miniature-Automotive-Light-Bulb
Eiko 5 watt .357 AMP 14 volt T3.25 Wedge Base #1450X Xenon Miniature Incandescent Eiko Light Bulb Lumens????
10watt might be a bit much.
...10watt might be a bit much...
You might just find melted plastic.
Another thing to look for while reading "those charts" is stuff like projected lifetime
I noticed you last bulb--the 50 watter--only had a projected life of 200 hours
Let's put that into perspective: If you say, were "on the road" and drove 10 hours a day, that bulb would only last 20 days!!!
The pre-'66 holders aren't easily available. The '66-up holders take the all-glass wedge-base bulbs and fit the dash circuit board holes same as the earlier holders. Standard # SP500A if your circuit board holes are 1/2" diameter, Standard #HP4090 if they're 5/8" diameter. Use W3W bulbs (e.g., Sylvania 2821) if you want ordinary dim dash lighting, W5W (Sylvania 2825) if you want considerably brighter, WY5W (Sylvania 2827) if you want considerably brighter and a yellower green color (or amber, if you remove the blue plastic balloons inside the instrument cluster).
My obsessive/compulsive disorder got the best of me.
Brand Part # Lumens Watt’s Hours Price
GE 25837 75 5 700 7.99
GE 89239 39 5 1,700 5.99
GE 18442 50 5 2,000 1.99
GE 25962 38 5 1,500 1.69
Sylvania 34711 38 4 1,500 2.49
W/house06204 38 5 2,800 2.19
Bulbrite 715510 100 10 10,000 1.99
Litetronics32580 50 5 2,000 .80
