GM caliper on my 66 Cuda?
999yards
eastern nc
I've had my 66 Barracuda for a few years now and have put many miles on it. The front right caliper needed replacing so I took it off last weekend. It is then when I discovered its GM caliper. It was already converted to a five lug front disk brakes before I got it.
Question is whether or not a GM caliper just so happens to fit Mopar suspension or do I need to dig further into it?
The caliper is a single piston floating type from years 79-02.
Lost contact with the previous owner.
That's an interesting kit. Certainly allows the use of a prolific, easy to find and possibly superior caliper.
The summit disc brake swap kit i bought years ago for my dart had gm calipers in it. i think it was a lower level SSBC kit they rebadged. i would just replace or rebuild the calipers and roll with what you have, considering off the shelf swap kits are readily using them.
Yea I don't mind even though I am a purist. Don't know what a Mopar caliper costs but the GM one I picked up from advance auto in stock was only $25.
I was worried that someone did a hack job when I first discovered it.
I wouldn't worry about the purist thing. Use what WORKS.
Pitchers would be a great help.
here ya go, but i really don't see how they will help with a brake caliper..:)
hi-res-163554376-pitcher-masahiro-tanaka-of-japan-pitches-in-the-fifth_crop_north.jpg
The Scarebird conversions use a GM caliper also.
X2 they are the right size and design to do the job. Just consider it a Delco/ Moraine brake part just like Mopar used Kelsey Hayes calipers.
