Go to street cam from the 70s-80s.
Crane cams bought Cam Dynamics years ago. GK also disappeared many moons ago. Comp bought Crane & the Crane brand seems to going also, just selling up old stock..
I thought S&S Cycles bought and owns Crane cams...?
I also thought General Kinetics was bought by Lunati, then when Holley bought Lunati GK was just shut down....?
My first engine build was a 440. I used the MPP 284/.528/112 solid cam. I used it many times after that in both my cars and friends cars. That's a great cam for a street/strip car.
Old 284/.484 DC cam in my 383 69 Charger. Almost 4300#'s of car...went 13.05 at about 105.5. Used to drive it 34 miles to Quaker City dragstrip and have some fun. But the 292/.509 DC cam in the 440 that went in later was my favorite!
I used that cam in my first performance LA build, a 360 for my '71 Demon. Worked fantastic on the street and pulled (I couldn't believe it!) 15-16"hg vacuum at idle (800-900rpm). Ran 7.80s in the 1/8mi with 273 valve gear and later ran 7.60s with 1.6 Crane rollers and some other tweaks. Always wanted to try one in a big block, especially after Andy F reported his dyno findings. Very durable and stable at RPM.
Okay I'm a little late to this party and did not have the opportunity to read every post but in the early '70s DC mocams weren't even available yet I will agree that the 508 / 292 hydrocam was a powerhouse in a high compression 340 with a set of 430 gears and an m1 single plane etc .but Ican't believe no one mentioned the fireball 300 by crane that was a go to 340 cam of the early 70s on the street. It came in with a intake of 226 at 50 and an exhaust of 232 on a 110 center I believe. combined with a LD 340 ,750 Holly ,headers a,4speed,410 gears you were definitely a Street bully!
I have that cam on my shelf. It came in a 340 I bought pulled out of a duster that was rolled. I think lift is like .447 which is ok for stock heads.
There was also one all the Chevy guys used. The 327 350HP cam. Tried as I did, I could not tell their stupid asses it was way too much cam for most applications they were using it for. That cam was made for 11:1 compression and most were stabbing them in 8:1 motors. .447 and 306 advertised and 222 @ .050 on a 114. None of them I ever saw would pull a greasy string outta a cat's ***. in fact, I outran one of them in a 71 307 2 barrel three speed Camaro I had. He was mad as hell too.
I hated the fn Chevy cam. Ur they all had to have it. Kim
Anyone ever used this one? Bought it used for 50$.
Yes that lift sounds about right, I also have a fireball 300 greased up in rags on the my garage shelf. I always thought it would make a great spray cam
Yes, S & S bought Crane, but now Comp Cams owns it. CC own a raft of companies. They own Holley, MSD, plus others, & recently bought Edelbrock.
Negative ghostrider. Edelbrock bought Comp.....and everybody else they own.
Somebody should tell Comp Cams that Edel owns them, not the other way round, because Edel is listed on the CC website as one of the many brands that CC owns.
Its hard to beat the 292/.508 Mopar cam, i ran it last year in my 360, but i switch to the modern day solid version from Bullet 282/.510, you would be surprise how many rpms you can turn with these specs.
