Good Streetabe Power
It was a blast to drive!! 3rd gear roll on burnouts, hanging onto the steering wheel as the car changes lanes on its own. Fun times for sure... And comments aplenty :thumbsup:
I yanked the wheel to the left about 30° as I power shifted 2nd in my CSX. It went straight, relatively.
Streetabe? WTF
This topic is tiring because in one form or another it gets done over and over again constantly. And setting and duration limit as street able or streetable HP is ridiculous because heeds, displacement, variations in bore and stroke all handle duration differently. All things the same a 360 should have a cam with 10 degrees more duration at .050 than a 318 just because of displacement alone plus it’s all relative to the total drivetrain combination.
I'm sure the engineers had a much more complicated formula, but 10° @ .050" for 42 cubic inches looks like a big jump. It's NOT.
Look what engineering did if you just compared bore size to everyday engine duration @ .050" vs performance pkg engine duration @ .050"
"Bore (cid) @.050" °/"
3.91" (318) 184° 47.05°
4.00" (360 2bbl) 196° 49°
4.00" (360 4bbl) 209° 52.25°
4.04" (340) 209° 51.7°
4.25" (383 2bbl) 206° 48.47°
4.25" (383 HP). 213° 50.11°
4.25" (426 HEMI) 228° 53.64°
4.32" (440). 206° 48.47°
4.32" (440 HP) 213° 49.30°
Using a non engineer derived duration formula shows there was a method to what they did. Realize they also factored in customer perception, mileage, and, warranty with a "5th percentile driver". Think 16yr old driving Daddy's new Cummins dually stick shift with a load of plywood on a Saturday night cruise in town.
Sorry AJ but use the HEMI degree per inch (°/") and the stock 340 cam looks great for a 318HP with a warranty. Factor in technology and the °/" @ .050" should go up and the advertised go down.
Bore @.050" °/"
If you separate, performance from non performance the latter has 22 degrees for a 122 cid spread and just slightly more 169 cid spread 273-440. And performance there's only 4 degrees for a 100 cid spread 340 vs 440.
If mopar made a high performance version of the 318 between 68-74 or so it probably would of came with more cr and a 340 top end including cam cause they would of used the parts they already had.
273,
Read what you were commenting about duration @ .050" to Oldiron440 and my comments about duration @ .050"
I believe Oldiron440 is being conservative or coming at this from a performance vs performance viewpoint vs. Mopar engineering considering 184° @ .050" 318 cam vs 196° or 209° @ .050" 360 cams. My math comes up 12° and 25° difference.
273,
I gotcha, and somewhat agree that a large cids tends to handle a little more duration, I do believe it has a lot to do with port size and flow ratio to cid so if a 273 vs 340 vs 440 all are built with a similar port size/flow to cid ratio then all would need a similar amount of time (duration) to fill the cylinders at a given rpm.
But don't believe it's black and white to how much more duration and obviously ain't too scalable aka degrees per cid.
But a 440 is 6-10 degrees more for another 80-100 cid, over 340/360 how does that fit ?
I'm referring to " bore size not cid.
I agree it
I'm referring to " bore size not cid. Let's work the math for a Hyd street HEMI
228 (°@.050") ÷ 4.25(440HP) = 53.64
Degrees per inch of bore
Plug that in for a 440
4.32 × 53.64 = 231
Smack in the ballpark where DC had the "HEMI" grind 280 cam (230° @ .050").
I agree it not a straight scale, but the " bore size to ° @ .050" has some merit.
I'm sure, stroke, port window, cfm, and many other things go into cam design.
I agree it
4.32 × 53.64 = 231
Why the focus on bore size ?
Don't see how it would matter much to duration ?
Even so a 318 vs 360 is only 0.090" difference vs the 0.320" between 360 vs 440 so 184 vs 196 compared to 196 vs 206 or 209 vs 213 still a 3-10 degrees for a 3+ x overbore and still don't show anything definitive.
Plus doesn't mean the factory is using any ratio of bore and or cid to pick needed duration, the 383 and 440 are running the same cams same with performance 340 vs 360 and basically not much difference between all 4 340, 360, 383 and 440 performance versions.
I'm a simpleton. This whole thread is about good streetable power. I use the simple factor with a street friendly LSA (110°-114°) to have good, streetable power. Is it perfect, no, but it works. Will it get the last available HP, no, but it works. There's gotta be a factor for stroke, rpm use, cylinder head type, cam base circle diameter, political party affiliation, etc.
The whole .050" rating system came about to standardize cam sizing because advertised was just that, advertised. SAE used .004", Crane .006, Mopar .008"
Questions about bore size.
Why did NASCAR teams run the biggest bore and shortest stroke within the confines of the cid rules?
Why did Pro Stock gravitate toward the largest bore and shortest stroke within the confines of the cid rules?
Why did Mopar never develop a taller deck A engine block, but offered bigger bore and bigger bore shorter stroke A engine block?
Why does the aftermarket have multiple ways to make a big bore LS engine (sleeves and big bore blocks) and precious few tall deck options?
Best street ripper "stoplight to stoplight"....
Pretty much any reasonably stout combo. Say 350 HP cruiser.
Toss a 200 shot on it. If you can manage decent traction... Maybe a 300 shot lol.
Everyone should experience a nitrous car at least once. It feels like you instantly engaged a rocket booster. It's violent lol
It's a turbocharger in a bottle. :thumbsup:
375 hp 318 vs 440
The way I see it, torque is mostly a byproduct, yes torque and rpm make power and power is what's needed, unlike power torque can be multiplied by gearing, tire size etc..
If you look at similar hp engines, torque, displacement, rpm and gearing are interconnected, basically a ratios of one another, engine size is roughly gonna fix where the rpm's that powerband has to be made at depending on torque which is heavily tied to cid, which generally lives in a fairly narrow range of torque per cid that with gearing that's necessary to optimize that powerband for the task which basically will put similar torque to the ground and more importantly hp to the ground at any given mph, why I see torque as a byproduct.
So a similar HP 318 and 440 geared optimally should be putting similar hp per mph to the ground same with torque but the thing with street cars most aren't gonna gear properly so what gears people generally run will typically favor the larger engine. aka 440.
Depends on what you mean by "gearing it properly " Are you gearing it properly for a drag race or for a Street car that is driven on the interstate?
We already discussed this at length, one more time, obviously "gearing properly" is a vague term it's all depends by the situations, but most people realize a engine that makes similar power at higher rpm needs more gear (generally a smaller engine) so if geared properly (take advantage of each engines powerband) both should be able to put similar torque and hp per mph to the ground, obviously there's variables, and this usually leads to but "I'll just run deeper gears with the larger engine" but gears aren't magic they only allow the car put use of the engines power for the task. So whatever gear you run in a 375 hp 440 you can always run deeper in a 375 hp 318 cause it has more useable rpm.
As for the highway has nothing to do with engines potential performance, for me I don't care about the highway you apparently do, that's a preference that you, not me, would have to design around if your worried about the highway run an O/D :)
It has everything to do with the potential performance of the vehicle the engine is in. When I have the conversation with a customer about how cubic inches will affect the potential performance of their vehicle vs cost and the gear they would like to use they will pretty much always choose more cubic inches within the family of engines they are using. To them it makes sense. Even this guy seems to agree.
"Main advantage of displacement is you can make desired hp at lower rpms which with typical street gearing (2.76-3.55) is a huge advantage, easier to get into the powerband at any given road speed"
It has everything to do with the potential performance or the vehicle the engine is in. When I have the conversation with a customer about how cubic inches will affect the potential performance of their vehicle vs cost and the gear they would like to use they will pretty much always choose more cubic inches within the family of engines they are using. To them it makes sense.
Strawmanning again, obviously most pick displacement over rpm, you don't seem to understand potential, so what if most will pick the 440 over a 318, who cares if only one in a thousand would rather build a 318 it changes nothing about an engines potential, again never said it makes more sense or whatever to build smaller, just if you do it's possible to have similar performance, so can you stop strawmaning the argument.
Again there's a difference between an engines potential and which one fits the application better.
But you also cut out half my quote bellow, where I acknowledged some may prefer the higher rpm engines.
but if you like higher rpm's (about 600 rpms with 318 vs 360) deeper gears higher stall etc.. for a given hp then 318 might more be your thing.
Not everyone wants what others want, don't know why some just can't accept that.
That's where we disagree. If the two motors were of similar performance you wouldn't need a deeper gear and more converter to make them equal.
That make zero sense, Eg,, do all cars that do around 12.00 in the quarter mile run same gear and stall ? or any other quarter mile time ? or 1/8 mile etc.. obviously the answer is NO.
Yes. Two motors can run 12.00's in the quarter mile with a wide difference in stall and gear ratios. Even though they both run 12.0s their performance on the street can be very different. It matters to people who don't only drive their cars at race tracks.
I think I got loss here somewhere. A good street able car should be one that can be stopped at a reasonable distance to avoid a crash. Most of our older cars are no longer street able, due to all the new braking systems. If I recall correctly, back in the 60's a factory streetcar could not have more than 500HP. Due to braking systems now, I'm sure the HP can or should be raised. Roads are also better constructed today, which would allow I higher HP. I think "Street able" should go along with "Safety". Take the unsafe cars to the drag strip and even those have safety rules for a reason.
This is the rub with asking questions about “streetable” anything, the perspective of what is street driven is as wide as there is people driving.
I come from a place where 4:88 gears, cams with close to 300 degrees of duration @050 and 12-1 cr was street driven and there are cars driven on drag n drives with the same plus a Gear Venders.
I personally like the loose converter big cam high horsepower street driver but I can understand that a little more than stock is something people want also but you need to have specific parameters for your question.
Street able in this thread only means idle, normal driving ability ain't too different from stocker, what most would find it reasonable, cause were using cylinder heads to build the power not stuffing overly large cams into a motor, kind of like stock LS and Gen 3 Hemi's etc.. make power.
Why your arguments are strawman, what's the difference running down the track or street other than traction, just cause I bring up track capability doesn't mean were talking about race cars, 1/4 1/8 mile 0 - 60, 0 -100 mph are measure of performance ability a car that's quicker on the track generally gonna be quicker in the streets. You want make an engines potential performance ability about other factors is why your stawmanning this.
