Ok thanks I will remeasure and write down what I find. I also found that the 8 1/4 rear is a ISO Clamp which is a bite in the butt
with your 8 3/4, earlier U-bolts, and shock plates, you can elimate the clamp and rubbers. the springs are the same as any other, nothing special
wow that much difference? you must have an early 8 3/4. mine is 47" from center to centerWell my housing won't work. I measured and my son measured too the 8 1/4 is 47 1/2 in -/+ from the pin to pin under the car. My 8 3/4 Housing is only around 44 in -/+ So for now the 8 1/4 stays.
hmmm, i dont know if the tabs on the back part of the k member are going to make it. it looks like you may want to just take it all apart. i have a feeling its going to crumble into pieces when you pull the bushing out. if it were me, i would drop the k member.
ops: No worries Cliff,I find you another !!!Well my housing won't work. I measured and my son measured too the 8 1/4 is 47 1/2 in -/+ from the pin to pin under the car. My 8 3/4 Housing is only around 44 in -/+ So for now the 8 1/4 stays.
Yesterday we hit 109...all time record for June...Today was much cooler 103...I do not even want to know how hot it was in my shop...Ok thanks I will do that when it cools off. Most likely in the morning. 102* right now.
Damn..Maybe a good reason for another road trip !!!
Glad to see you are making progress.
Back to work got a job I got to finish up a car tonight when it cools off a tad...
Martin
Wow,Cliff! Makin Progress! If interested,I have a pair of Holley (same as M/T) valve covers.Yurs,if you want.May take awhile,(gotta scrounge up freight!).,if interested.......
