Green Envy
no problem Cliff, they are pretty clean, i soaked and i chased all the nuts and bolts, so they are ready to go. a little at a time youll get there :D
thats pretty bad. nothing that cant be repaired , as long as you have good metal to work off of. i hope the main frame rails are solid
It seems to be so far. The hammer test will be next when I can get it up on jackstands.
Hey,Cliff here is the link for the drivers side Floor from front factory seam to behind the seat.
http://www.autobodyspecialt.com/cgi-bin/commerce.cgi?preadd=action&key=MP-197L
Also here is all the b-body parts they sell ...If you scroll down 1/3 of the way down they have rocker panel covers no picture though.
I called them before ordering panels for my 1963 Dart,they are really helpful and I am happy with what I received....
Here the B body page:
http://www.autobodyspecialt.com/cgi-bin/commerce.cgi?search=action&category=0010
Glad to see you getting after it !!!
Also here is all the b-body parts they sell ...If you scroll down 3/4 of the way down they have rocker panel covers no picture though.
Thanks Martin, I went there after we talked and found the one I needed.
http://www.autobodyspecialt.com/cgi-bin/commerce.cgi?preadd=action&key=MP-50R
Now I am looking for a trunk lid. Not easy to find.
just weld a 1" x 1" piece of square tubing in between the frame and the k frame and it will be just like a 72 charger.....or a stock car...you wont notice.....
I think the purpose of the rubber grommets is to isolate/dampen any vibration from the engine to the body. Will those dampen the vibration or transfer it?
Cliff,I would call them first because I believe they got the description wrong and you need this one because L denotes Left and R denotes Right....
Here the left with the same description of the right
http://www.autobodyspecialt.com/cgi-bin/commerce.cgi?preadd=action&key=MP-50L
After I replace the floor in my car what is a good rust preventative to apply over it. I don't want anything that will peel.
I have a body guy that likes to use that Por15 to keep rust from spreading. That should do good on your floor.
Hey Cliff:
I got you a black carpet on the way with a brand new (NOS) console. The console is just the plastic only, you will need the woodgrain part that runs the length of the console, a shifter mechanism, and the linkages.
I've also got a few leads on:
1. Overflow bottle
2. Pass fender
3. Set of nice doors
I have already spoken to the sellers and have them on reserve. I will meet with them over the next couple of weeks to pick them up. Then I can bring them down next month when I come get my hand truck.
