68dodge
I want to change headers on my 65 dart with a 360. I have fenderwell headers now. What kind fit nice and do you have any pictures.
1964-66 273 Abody manifolds work nice,
I heard somewhere that the original supplier of the Spitfire headers no longer makes them and that Layson's bought the rights/tooling and is now the one who does. Anyone know for sure?
not to hijack this thread but, do the TTIs and Dougs have issues with power steering on the 67-69 Barracudas, or only the earlier ones?
Don't the Hookers have 2 tubes through the fenderwell or something like that?
1964-66 273 Abody manifolds work nice, especially, if you are mostly
using the car for street driving, vs as an all out race car. ;)
I am using a 318 with # 302 heads, and a .430/.450 Mopar cam,
duals off the stock 273 manifolds. I am using a copper exhaust gasket
on the drivers side.
I am using a small Mopar stater ala/ 2002 Dakota style.
http://www.youtube.com/watch?v=Ud8mci4rjFU
is your car unmuffled? its nearly a duplicate to my engine combo but seems alot louder, even than when I had my nasty 3" stuff
http://vids.myspace.com/index.cfm?fuseaction=vids.individual&videoid=28818014
Using Dynomax Super Turbos, 2 1/4" pipes,
{starts at the stock manifolds as the stock size}.
The compression is up slightly, from the #302 heads,
on the 318, and it does have the Mopar P4452759 cam.
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 1,200-5,200
Intake Duration at 050 inch Lift 221
Exhaust Duration at 050 inch Lift 228
Duration at 050 inch Lift 221 int./228 exh.
Advertised Intake Duration 260
Advertised Exhaust Duration 268
Advertised Duration 260 int./268 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.430 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.450 in.
Valve Lift with Factory Rocker Arm Ratio 0.430 int./0.450 exh. lift
Lobe Separation (degrees) 110
those headers are for 67-76 a-bodies, e-bodies, and some b and f bodies, they will not fit early a bodies. early a bodies being 63-66.
